Page 2 of 2
Re: starter motor blowing fuses
Posted: Thu May 22, 2014 5:09 pm
by JETEX
Appreciate that mate, I think what I was trying to get across was that if the starter is operating normally, then the OP will have to look elsewhere for the short circuit I.e : the starter button or wiring.
Posted: Thu May 22, 2014 5:38 pm
by wack 63
I would check the wiring into the safety interlock under the horn casing, the clutch switch wiring and the starter button first.
Posted: Fri May 23, 2014 9:13 am
by KCB
ok thanks, the starter motor does work, it is when you release the starter button that the battery fuse blows. I guess the short could be in the starter switch or clutch switch in that case.
