Page 2 of 2
Re: 42L2 T5 Conversion; Carb problem
Posted: Mon May 05, 2014 12:44 pm
by GLscoot
Andrew
Pictures of the frame clearance at the carb manifold
IMG_3608 by
GLscoot, on Flickr
IMG_3610 by
GLscoot, on Flickr
I have not bottomed out yet.
Gary
Posted: Mon May 05, 2014 7:14 pm
by goldeneye
just cut the frame man. so much stuff to do to get round a simple problem, you've already altered it to put a T5 motor in and will no doubt be altering more to make it rideable in the real world, will a small cut on the frame, unseen with the panel on, be such a big deal? its never going back to standard , so whats the problem? get the grinder out!
Posted: Mon May 05, 2014 9:33 pm
by GLscoot
Thats the easy option. If you are wanting to keep the value of the frame, try and not cut the frame. If your not bothered then by all means get the grinder out. If you do cut the frame, try and do it in one go and keep the part you cut off so it can be welded back on.
If you fit the dellorto phbh carburettor, cut the manifold and turn it out (away from the frame) you may need to cut a bit of the flywheel side casing for the carb to fit. I don't know how much room you have under the side panel, height wise. PHBH carb might be to big.
Gary
