Re: Shed Find (My Shed)
Posted: Sun Apr 20, 2014 11:18 pm
It all goes a bit quiet during October and November of that year, I was busy with work and the weather was bad.
In the Xmas break I get out into the shed and drop the front wheel out.
This is also suffering fairly badly from the passage of time, and at least one winter in the old shed which had been leaking and damp which is when I'm sure most of this damage occurred.
I start to strip it down, the corrosion on it is every bit as bad as the rest.
This doesn't look to bad but if you got your nail under an edge the whole thing was lifting off in a single piece and usual white powdery stuff was everywhere.
The speedo drive gear is bust as well.
Yet another box of rusty parts added to the collection.
Just noticed this was being done on the on the dining room table
the missis must have been out
I make up my mind that when the casings turn up from cleaning I'll get this blasted and coated again. My plan was to do the front hub, rear hub and side casing as per the original but decide to change the colour for a gunmetal metallic.
I should say at this point that my brother-in-law was doing the blasting on the engine casing as a favour and this was taking a little longer than I'd planned for but you can't push somebody who's doing you a favour too hard.
It all goes a bit quiet for a while again.
