Page 2 of 2
Re: Gearbox noise
Posted: Thu Apr 24, 2014 1:44 pm
by Strummer10
Opened the case last night and painted the kickstart shaft with 'Tippex' where it lines up with clutch plate ....turned the engine a number of times but no signs it was wearing off the Tippex !! Then changed the gearbox complete just in case worn gears and still have that mild sound. I do have new crank, seals, bearings, chain , seals so maybe it just needs bedding in......done about 40 miles since rebuild....new piston rings also
Re: Gearbox noise
Posted: Thu Apr 24, 2014 2:37 pm
by johnny LIS150
did you remove the clutch assembly to see if the back of the basket was rubbing on one of the endplate bolts or something out of sight ? Maybe a worn or wrong sized shim/s between the bearing and clutch carrier? taking up float in the mainshaft. You can get different shim thicknesses to space it more if needed
Re: Gearbox noise
Posted: Fri Apr 25, 2014 10:11 pm
by Strummer10
Yes checked endplate bolts and were ok, then checked shims against others and the play about the same...........maybe just me being paranoid about the slightest noise.....
