Re: Exhaust advice for low down touring.
Posted: Mon Apr 14, 2014 1:03 pm
Its difficult when you really need to compare some scooter with the same gearing set up as you. Its no good if you STILL have to mess about. Nearest comparison I could find was this... ''I run indian GP200 box 19/46 sprockets and it pulls 4 brilliant from 30mph upwards...I wouldnt use anything else - new TS will have another SS one on...I also fitted a SS one to a mates TS engine i built - again no problems'' I have an SX200 gearbox with 16/46 sprockets & its brilliant with a clubman on the flat, but it just doesn't pull uphill well enough as I found out to my cost on c2c.. Now, I spend £189 from Scooterotica Scooter Garage on a taffspeed copy & hope for the best, or end up having to change to a 15 tooth front sprocket for pulling power uphill only to find it revs too much on the flat, or worse still start looking about for ANOTHER Li150 gearbox.
