Exhaust advice for low down touring.
a.j
Its difficult when you really need to compare some scooter with the same gearing set up as you. Its no good if you STILL have to mess about. Nearest comparison I could find was this... ''I run indian GP200 box 19/46 sprockets and it pulls 4 brilliant from 30mph upwards...I wouldnt use anything else - new TS will have another SS one on...I also fitted a SS one to a mates TS engine i built - again no problems'' I have an SX200 gearbox with 16/46 sprockets & its brilliant with a clubman on the flat, but it just doesn't pull uphill well enough as I found out to my cost on c2c.. Now, I spend £189 from Scooterotica Scooter Garage on a taffspeed copy & hope for the best, or end up having to change to a 15 tooth front sprocket for pulling power uphill only to find it revs too much on the flat, or worse still start looking about for ANOTHER Li150 gearbox.
a.j
Well I just bought a taffy copy off Dan, time will tell. Hopefully wont be pestering you lot about it anymore.. :lol:
