Avanti set up
corrado wrote:I'd try a smaller pilot jet.
I'd try a Dellorto
SpanishSX200 wrote:......everything fell apart at the same time. Plating of the slide, jets with pieces falling off, needle worn to not a lot...,.
I refuse any Dyno work with these carbs fitted. I don't like them at all.
OAP
I was trying to be diplomatic Dan, but ditto
OAP wrote:......Or you can arrange to call in and I will stack your bike on a test run.
:shock: :shock: :lol:
dapper
Ron, no offence meant at all. Wasn't calling your advice into question and I did state that the advice you gave me was from someone who was running a similar carb but did not state that you had set it up. I have good friends who swear by Dellies,, but I have never worked on or used one. I was given the OKO by a mate (who swears by Dellies :lol: ) who didn't like it and I did all the mods to try to make it run ok cus I'm tight :roll: I'll see how things go and report back :oops:
This is on utube, Avanti running a Kiehin PWK
https://www.youtube.com/watch?v=S0PypHKPels
