Page 2 of 2
Re: Lectron Carbs
Posted: Tue May 06, 2014 8:42 pm
by TED CRUD
I don't know about different, i have read reviews watched you tube .They Perform really well on the Honda CR 250, it makes sense to me as I am going to use this Barrel on my GP
Re: Lectron Carbs
Posted: Wed May 07, 2014 1:52 pm
by dapper
Video 8 was interesting where he used a digital laser temp guage (which I happen to have ) to measure EGT. I suppose you'd point it at the down pipe around 10cm. from the flange and see what temp you get. Adjust the carb to get the lowest reading at tickover and then see what temps occur at different throttle positions. What would be suggested EGT for an Avanti kit? I imagine someone out there has an EGT fitted to an Avanti by now.
Re: Lectron Carbs
Posted: Wed May 07, 2014 2:50 pm
by TED CRUD
http://scooterotica.org/forum/viewtopic ... 76#p205576
As i am going fully water cooled .I will be using the above air flow ratio meter
Re: Lectron Carbs
Posted: Wed May 07, 2014 8:12 pm
by willwander
I used one in late 80's
They are an old design, very simple and therefore effective.
I expect they flow well as they are popular on drag bikes and you can get really big ones (41mmm+).
Getting the right 'rod' and therefore good jetting can be tricky and work out expensive. I'd like to try one with a fancy power jet like foxhat.
Having said all that I'd be surprised if they do add much compared to a well set up modern carb.
Re: Lectron Carbs
Posted: Wed May 07, 2014 9:07 pm
by TED CRUD
this one has a power jet and has been Dyno`ed t for my set up ,by Lectron .Apparently the Lectron is less susceptible to atmospherics .I hope with the air flow ratio meter everything will be kept in check .I have also bought a range of Metering rod and a few spares ,just in case
Re: Lectron Carbs
Posted: Wed May 07, 2014 9:18 pm
by TED CRUD
Re: Lectron Carbs
Posted: Wed May 07, 2014 11:46 pm
by Darrell Taylor
got a new 32mm lectron up for grabs
