Page 2 of 3
Re: T5 172 Setting up.
Posted: Wed Apr 02, 2014 6:17 pm
by goldeneye
wanged the 172 from Aspatria in Cumbria, over the A66 to Middlesbrough, then up the A19, set on 16degrees...it didn't blow up.....
Posted: Wed Apr 02, 2014 6:26 pm
by soulboy
golden eye were is 16d on the stator
Posted: Wed Apr 02, 2014 6:30 pm
by sean brady scooters
16 is std marks on a t5
but turn your stator clockwise a mill or so and it will be nearer 14
Posted: Wed Apr 02, 2014 7:07 pm
by soulboy
so I was told anti clockwise so that was wrong then mate ive seen ur work mate and ur word is good enough for me
Posted: Fri Apr 11, 2014 10:43 pm
by jackskater
fitted it all yesterday been out for a bit of a ride and covered about 30-40 miles, plugs running a bit lean so im gunna put a 130 in and it should run spot on, before anyone says thats too big, my airfilter is pretty haggid and has the heart drilled out rather large aswell lol
Posted: Fri Apr 11, 2014 11:13 pm
by Yanker
Ran mine @ - 1.5mm btd on the Scooterotica scale - 15.5 BTDC degrees on the degree scale. Solid for full throttle 100 Miles an another. 172, PM head, reed Phbh set-up etc. Only retard from the the 16 mark on a T5 if your head is unaltered per Std Malossi kit! (or u r pinking) IMHO
Posted: Sat Apr 12, 2014 5:27 pm
by acko
I've got 3 Malossi 172 and run em all at standard setting 16 degrees.
Covered thousands of miles over the years.
Never missed a beat.
Posted: Sun Apr 13, 2014 5:21 pm
by soulboy
so whats causin the indent on the top of my piston
Posted: Wed Apr 16, 2014 3:52 pm
by fastfrog
head bad shaping??
Posted: Wed Apr 16, 2014 7:41 pm
by soulboy
the head was done by chislespped I got it off ducksta on here I think so I no nothing wrong with that
