Page 2 of 2
Re: fuel consumption malossi 220
Posted: Tue Mar 25, 2014 7:38 pm
by Morgan
Might be worth considering a Dyno session. With what your spending in fuel it may be cost effective.
Posted: Tue Mar 25, 2014 10:14 pm
by Ginch
Jack221 wrote:So, what jets/atomiser you got fitted right now?
The atomiser number is the size. As small as possible (often rnds up as 264 on a Malossi). You feel the atomiser size when the throttle is open an 1/8th
Oops sorry! I was thinking SI carb.
Posted: Tue Mar 25, 2014 10:16 pm
by 1469leach
Thanks for the comments and to answer some of what's been said ! No I don't Cain it everywhere,it's got a final drive ratio of 4.77-1,I wanted to try and make it as torquey as poss lower down to pull longer gearing,the jetting has been played with over the last couple of months but I have run it with an av 264 atomiser and an x2 needle but just trying it with a av 266 with an x7 and it seems a bit clearer,the slow running jet is a 58 but I may go for a 55,the main jet is 145 and it still feels like it's not rich,fuel consumption seems near enough the same regardless of the different jetting,revs out over 8 k in 2nd no probs so jetting can't be that far out can it?
Posted: Wed Mar 26, 2014 5:12 pm
by philhnottm
I get about 55 miles per tank similar set up which has been dialed in on dyno.
Sent from my GT-I8190N using Tapatalk
Posted: Wed Mar 26, 2014 5:13 pm
by philhnottm
My main jet is 105 ( big difference from above)
Posted: Wed Mar 26, 2014 5:32 pm
by sean brady scooters
your gearing sounds to tall TBH so maybe your spending most of your time riding in 3rd gear ?
Posted: Wed Mar 26, 2014 7:25 pm
by Jack221
Your pilot jet is way too big! 52 should be enough. The X7 is a fat ended needle and on a powerful motor that revs high it wont open enough at full throttle to flow the main jet. Something like an AS264 and an X3 needle will suit it better
Posted: Thu Mar 27, 2014 10:36 am
by Bifter
I used to get about 60 mpg on mine with a 124 main dyno ed by paul baker ,but i could never let it go below a 1/4 tank as it didnt want to run then
