Page 2 of 9
Re: Taffy copy pipe
Posted: Fri Mar 21, 2014 10:23 pm
by simonwwfc
My last one I bought direct from dan on here never had issue . Only small trimming to rear runner it's only this one I have . The mercano bracket I couldn't use as not long enough when fitted . It sits the same height as a original taffy exhaust
Re: Taffy copy pipe
Posted: Fri Mar 21, 2014 10:26 pm
by simonwwfc
Re: Taffy copy pipe
Posted: Fri Mar 21, 2014 10:28 pm
by simonwwfc
Someone said try ts1 engine cones something to do with offset :idea:
Re: Taffy copy pipe
Posted: Fri Mar 21, 2014 10:43 pm
by boris
What:shock: fit new cones again. I only wanted to fit a bog standard expansion pipe now I'm having to take the engine out again. I love scooters
Sent from my HTC Sensation Z710e using Tapatalk
Re: Taffy copy pipe
Posted: Fri Mar 21, 2014 11:03 pm
by joespeed
so is this a jl 3/4 copy?
try removing the two front bolts that hold the exhaust to the bracket slack of the rear tail pipe clamp or remove then see if the exhaust will drop down at the back and up at the front tighten tail pipe up and mark the front holes then redrill or elongate,at no time swinging on the pipe forcing it to fit or it will fracture when in use!
Re: Taffy copy pipe
Posted: Fri Mar 21, 2014 11:18 pm
by boris
It's as tight as arse holes.
It's taffy copy.
It's sat well low enough without the main front bracket.
But is to low to re-drill the holes. I have already made them bigger with the dremel.
I know its a copy and I sound like moaning tw@7. But the fit is shite.
Don't get me wrong it sound great looks good. But does not fit.
Re: Taffy copy pipe
Posted: Fri Mar 21, 2014 11:20 pm
by simonwwfc
joespeed wrote:so is this a jl 3/4 copy?
It's a taffy replica joe . I've already tried this mate I'm gonna get runner fabricated to fit
Re: Taffy copy pipe
Posted: Fri Mar 21, 2014 11:24 pm
by simonwwfc
I've spent hrs fiddling about with it trying to get it lower but u cannot . Only other way is get runners fabricated or get short stainless runners and get them painted as I've done but haven't fitted them yet ;) gonna have a go tomorrow
Re: Taffy copy pipe
Posted: Fri Mar 21, 2014 11:42 pm
by joespeed
i'd be tempted to cut and twist on the front pipe under the main frame tube how much was this pipe?
Re: Taffy copy pipe
Posted: Sat Mar 22, 2014 12:31 am
by rosscla
joespeed wrote:i'd be tempted to cut and twist on the front pipe under the main frame tube how much was this pipe?
http://scooterotica.net/userimages/procart11.htm
The pics do look low at the front,
