Page 2 of 2
Re: TS1 starting issues
Posted: Sat Mar 22, 2014 10:25 pm
by drunkmunkey6969
Darrell Taylor wrote:the boyessen reeds fitted have probably failed due to entering the bore and clipping the edge of the piston if fitted without a few gaskets to raise the reed out a bit ,the problem exists as the fixing plates without petal stops allow the petal to lift too far i would fit stops back on for long term reliability
the moto tassinari reeds fail quickly if you have the wrong block/reed supplied ,the correct ones last just as long as an original
Good info. Not spacer/piston related, but I blew 2 sets of V force 3 on a TS1, these had no stops. Fitted V force 4.....same block but with stops, no issues now for many miles.
Posted: Sun Mar 23, 2014 11:44 am
by Darrell Taylor
more info from long term testing and development on road and dyno
vf3 petals were changed mid product life for a set that worked well on a banshee but failed in a lambretta so most sold in last 3-4 yrs have these ,earlier vf3 petals are still going strong 4-5 yrs on
the recent/current std ts1 reed block has the same problem with the reed petal plate that allows petal to enter bore and cuts a half moon out of the top reed petal
the vf4 has issues too if not identified !!! fortunately the ones i sell are sorted ;)
