Re: MB Clutch Springs vs Readspeed Clutch Springs....
Posted: Fri Feb 28, 2014 9:52 pm
What did you use in the GT from the start and dis they perform well?
The UK's No1 Lambretta & Vespa Scooter Forum.
https://www.scooterotica.org/forum/
Ok thanks. Don't use the power then...eden wrote:I used some old s**t I had lying around the garage floor, they lasted ok while taking it easy but soon f@@ked up once I started using the power.
Well spotted Mick, the MB definately has an extra turn / coil, could be the answer right there!mick1 wrote:Could be the pictures but the MB spring wire looks slightly thicker, also (again could be the picture) the MB appears to have 7 turns whereas the RS has 6.......or is it me ?
It does have an extra turn/coil.....well....about 1/2-3/4 actually, hence its 1mm longer from the start. But the point is, after compression....the RS one is about 5mm shorter than its starting length, and doesn't return to full pre-compression length. This in my humble opinion is probably due to the material/metal composition rather than the 1mm difference.Bert Oni wrote:Well spotted Mick, the MB definately has an extra turn / coil, could be the answer right there!mick1 wrote:Could be the pictures but the MB spring wire looks slightly thicker, also (again could be the picture) the MB appears to have 7 turns whereas the RS has 6.......or is it me ?
If you are referring to the Reedspeed budget 5 plate, I have been running them in a TS1 and an Avanti 225 both with MB springs and have had no issues at all. The Avanti has been up and over the Hardnott Pass (lots of clutch slipping needed) and also did a 1600 mile round trip to Davos in Switzerland last year with no slippage and an easy clutch action.cgt75b wrote:Hello
Was there any feedback on how the reedspeed 5 plate clutch performed ? I am thinking of buying one.
Thanks for any help.
