RB20 (200cc) - Pictures and Spec
noggin1969
Have the price of 150 blocks just shot up on E.Bay ? :lol:
Has a mind full of useless s**t and isn't afraid to use it !
J1MS
Want one :shock:
J1MS
Just been on A.F. Rayspeeds site, no Dyno charts on there, only for the RB225. It must have been run on a Dyno at some point, so where are the print out's :?: Still want one :P
RBG
Have all 150 casings got as much meat around the transfers as the Indian GP150 has?
I do really like the look of this kit & have a S3 LI150 motor knocking around.
Adspeed
RBG wrote:Have all 150 casings got as much meat around the transfers as the Indian GP150 has?
They're made using the same as the 200cc casing but with a 150cc casing mouth.
yes its 30mm comp height,and 66mm bore.....
RBG
eden wrote: Does anyone make base packing plates for the 150 casings?
You know were I'm going with his ;)
http://www.lambrettaspares.com/sparepar ... 00m30.html
AndyS
I know that the garph, which is taken from the Af website, is not very technical, but it looks to me that the RB20 has more peak power that the RB22.
Image.
I too have thought about the small block, a Gp150 one went for abot £30.00 on ebay yesterday
maxi
Main scooter: LIS 190
is there any other crank you could use with a 116mm rod?or do you have to you use afs rb one?
cheers maxi
Ride it hard
stockcar
what sort of costings apply to the bits you have gathered together, looks very interesting
