Page 2 of 2
Re: rapido 225 with 116mm con rod
Posted: Fri Jan 24, 2014 11:21 pm
by Yanker
steveg wrote: Yamaha DT 250 piston
AF re-profiled Head (yam spec)
Rapido Boost ported cylinder
Reed-valve
Intresting: Why not the new Wossener RB/TS/Rapido 70mm piston with 16mm s/e bearing and RB20 rod?
Posted: Sat Feb 01, 2014 4:56 pm
by dave wheeler
I was planning running a 24mm dellorto and conservative porting so not really wanting a reed valve, anyone know of a source of non reed valve pistons beyond the MB ones which are a bit pricey
Posted: Sat Feb 01, 2014 5:02 pm
by dave wheeler
I presume a 9mm packer plate and using a conventional piston is not ideal
Posted: Sat Feb 01, 2014 8:00 pm
by Yanker
dave wheeler wrote:I was planning running a 24mm dellorto and conservative porting so not really wanting a reed valve, anyone know of a source of non reed valve pistons beyond the MB ones which are a bit pricey
There is a range of Mugello pistons for the TV/116 rod. Dunno if that includes the 70mm/225cc: Try CamLam. 9mm Packer is gonna throw-up more work and problems (blending, cowl, cylinder fitment in frame).
