Re: New Rear Shock from Readspeed
Posted: Sun Jan 19, 2014 7:46 pm
they look adjustable with a threaded/lock nut - blue nut on top eyelet (Top on th picture)
looks up my street for S2
The UK's No1 Lambretta & Vespa Scooter Forum.
https://www.scooterotica.org/forum/
What ! pinks not manly ? ....its the new Matt BlackDoom Patrol wrote:You've got to look at it in perspective. When a new set of BGM dampers cost more than that it sounds reasonable. You could perhaps have chosen a more manly colour though.
There adjustablefred wrote:How long are they?
Will that actually alter the length or just the load on the spring? I'm also curious about the length as the mention in Scootering said suitable for series 1, 2 and 3gaz_powell wrote:they look adjustable with a threaded/lock nut - blue nut on top eyelet (Top on th picture)
The locknut is on the bottom eye, it adjusts the length the same as a BGM rear shock by the looks of it.coaster wrote:Will that actually alter the length or just the load on the spring? I'm also curious about the length as the mention in Scootering said suitable for series 1, 2 and 3gaz_powell wrote:they look adjustable with a threaded/lock nut - blue nut on top eyelet (Top on th picture)
Thanks Mikesoulsurfer wrote:The locknut is on the bottom eye, it adjusts the length the same as a BGM rear shock by the looks of it.coaster wrote:Will that actually alter the length or just the load on the spring? I'm also curious about the length as the mention in Scootering said suitable for series 1, 2 and 3gaz_powell wrote:they look adjustable with a threaded/lock nut - blue nut on top eyelet (Top on th picture)
