Page 2 of 2
Re: Which cylinder head for malossi 220
Posted: Sun Jan 05, 2014 12:02 pm
by bogs
Tried both , but for purpose of trying to reduce pinging I use be3 as its richer but in a malossi I had a few years ago I ran ac 140, be4, 2.4 pj and 130 mj but this engine just 4 strokes on those jets or anything like.
I want to give a new head a go but not sure which to go for and will do dyno
Posted: Sun Jan 05, 2014 12:34 pm
by bazman
Yes I used a be4 with my old malossi it cleared the mid range up.
Do you know the head volume to get the compression ratio, as If too high you could get altered to suit? Rather than new head.
Posted: Sun Jan 05, 2014 11:57 pm
by ricalnic
Posted: Mon Jan 06, 2014 8:30 am
by ArmandTanzarian
I was once told that a P2s should have a squish of 2.5 to 3mm and a compression ration no higher than 10:1. Not sure if that applies to Malossi kits.
The squish sounded huge to me but I respect what he says.
Posted: Sat Apr 12, 2014 10:42 pm
by Norrie Bodge
Look here regarding emulsifiers ->
http://scooterotica.org/forum/viewtopic.php?f=8&t=27378
I run my 210 on 160 - BE2 - 128 using - T5 24/24g carb
