Re: Polossi 220?
Posted: Wed Jan 01, 2014 2:20 pm
I got my ones from Scootre centre, sip didn't have any in stock. And yes ali barrel, just done a 221 for a mate , and doing the 210 kit for myself at the moment.
The UK's No1 Lambretta & Vespa Scooter Forum.
https://www.scooterotica.org/forum/
Phil I'm going for almost the same set up, 60 mm crank etc, I holed my original piston, so stripped engine and doing rebuild. The sealing pad has slight score marks so I'm going reed valve as well. I'm going for the GS piston as the Polini piston top ring is a 'dyke' ring, like an L shape. With the 60mm crank the piston will be 1.5mm nearer the head, getting MMW 60mm head for it so no packer plate needed. The 207 piston as I understand it is 68mm whereas the 210 Ally kit is 68.5mm. Have you considered the Polini 221 kit, comes complete with head and bolt straight onto 60mm crank? I would but my 210 barrell is fine so can't justify spending out on a new kit. Good luck.philhnottm wrote:As the other thread shows I killed my diablo moto polini![]()
Im now going to go for the aly kit as opposed to the steel 208 that was fitted as I had a couple of high speed heat seizes on the M way
So questions!!
Will the new ally 210 kit work with a 60 ml longstroke crank that was fitted (which will also need replacing) ??
Do I need a different piston or will the new polini piston fit without any issues
Do I need to fit a GS piston which was fitted to the steel 208 kit??
Is there any real benefit to fitting a GS or malossi piston ??
Prior to destruction it was nearly 20 BHP and almost 19lbs of torque so not a balls out racer but a good tourer that pulled well .
I've now decided to go for ( on the re build)
New Polini alley 210 kit
SIP MMW head (same as fitted before)
Pinasco 60 ml longstroke crank (same as what Diablo fitted on the original build and set up)
Delorto 28 ml carb ( no reedvalve)
Delorto fuel pump which ive told I need with this set up.
As the tuning work has already been done im hoping this will be a re build with almost one for one swap with destroyed parts??
Really value any opinions advice on the above
Thanks
Phil
Assuming you are talking about new the long stroke version:joeythescooterboy wrote:How easy is it to do a Polossi using the new ally polini kit?
Jack221 wrote:None will beat my highly modified iron 207 with a malossi piston tho !!
