Page 2 of 3
Re: Uprated Lambretta Clutch...
Posted: Tue May 19, 2009 7:31 pm
by mark
my readspeed one is a light two finger clutch so i would get your m8 to check routing and fit a taffspeed nylon lined cable .
Posted: Tue May 19, 2009 8:00 pm
by soulsurfer
mark wrote:my readspeed one is a light two finger clutch so i would get your m8 to check routing and fit a taffspeed nylon lined cable .
Nylon fitted and routing fine, I can only assume he was sent the wrong springs
Posted: Tue May 19, 2009 8:02 pm
by corrado
I'm going to be fitting the same set up as JIMS in the race scoot but I'm also building a Rapido 250 that I'm putting one of the SSC motor bike clutches into, despite my reservations on it's build quality.
Funilly enough the one person who looked at it at Wicksteed (a well known top tuner who has his own clutch on the market) who I expected to tear it apart, was the one person who thought it was fine. Not sure at the moment which oil to use with it.
Posted: Tue May 19, 2009 9:04 pm
by soulsurfer
Who makes the "Japanese clutch"?
Posted: Wed May 20, 2009 11:27 am
by drunkmunkey6969
soulsurfer wrote:Who makes the "Japanese clutch"?
The Japanese.
Posted: Wed May 20, 2009 5:34 pm
by corrado
The one I'm using is made by morris-lambretta who posts on here. Thinks he's from Thailand and makes the clutches for SSC.
Posted: Wed May 20, 2009 8:32 pm
by soulsurfer
Is it the same as the one on here?...
http://scooterotica.org/forum/viewtopic ... tch#p19900
How much are they?
Posted: Wed May 20, 2009 8:33 pm
by col@garageartwerks
i'm like you shocky... when i first built my ts1 i went through clutches every 100 miles so got in touch with jem booth who told me to put an original italian spider in because they are cyanide hardened (marked with a triangle on the underside)... managed to prise one off jem and rebuilt clutch using surflex b plates (4) and taffspeed uprated spings.... clutch was in for 3 years attending loads of runs and rideouts mostly 2 up for a full year .. never held back on the power and alot of the rideouts were up hill and down dale... only replaced the plates for this year because i felt i had to not because they were knackered....
Posted: Wed May 20, 2009 8:38 pm
by soulsurfer
soulsurfer wrote:mark wrote:my readspeed one is a light two finger clutch so i would get your m8 to check routing and fit a taffspeed nylon lined cable .
Must've been supplied with the wrong springs, they've now been changed and it's much lighter.
Posted: Wed May 20, 2009 8:53 pm
by mark
good to know mate .
havent forgot to ring you just waiting for euro to be gone then i will call about electrics
