Page 2 of 3
Re: PX 58mm stroke crank
Posted: Mon Nov 18, 2013 9:10 pm
by ducksta
will pop over to run my eye over it for you we all know what happend last time you got the spanners out when my back was turned.
Posted: Mon Nov 18, 2013 9:40 pm
by mick1
Bearing in mind this might be the solution for a Vespa to keep up with the York Avanti Riders.....
Posted: Tue Nov 19, 2013 8:54 am
by ducksta
we will see, project x in the pipe line avantis ive s**t em
Posted: Tue Nov 19, 2013 9:12 am
by goldeneye
you"d struggle to get an Avanti barrel and head to fit in the frame ,they have much fatter fins than a standard lammy barrel.
Posted: Tue Nov 19, 2013 9:14 am
by drunkmunkey6969
mick1 wrote:Bearing in mind this might be the solution for a Vespa to keep up with the York Avanti Riders.....
No, you are thinking of an alloy Polini 210 with a Mallossi Piston, long stroke crank, Scooterotica porting job, and a decent pipe.....lol.
But I like your project better....
Posted: Tue Nov 19, 2013 9:47 am
by ducksta
shhhhhhhhh Dan keep me updated on Micks build want to know what ime up against
Posted: Tue Nov 19, 2013 9:50 am
by ducksta
goldeneye wrote:you"d struggle to get an Avanti barrel and head to fit in the frame ,they have much fatter fins than a standard lammy barrel.
obviously you dont know Mick or mick the grinder we call him
Posted: Tue Nov 19, 2013 10:43 am
by drunkmunkey6969
Posted: Tue Nov 19, 2013 3:41 pm
by ducksta
the bar was called the blue oyster bar if i remember
Posted: Tue Nov 19, 2013 7:20 pm
by mick1
ducksta wrote:the bar was called the blue oyster bar if i remember
Sigh............ok Ducksta if you want to go down that road.
Kindly explain why you were naked on Brighton beach with another man ?
Kindly explain why you then accepted a lift, whilst still naked,from a complete (male) stranger ?
Kindly confirm that you and the second naked man on Brighton beach both had "Magnum" tashes......and it wasn't November.
Kindly confirm, so there is no doubt what-so-ever that you are a Vespa rider
I patiently and with wry amusement await you reply......
