Page 2 of 4
Re: Burnt out Clutch
Posted: Sun Nov 17, 2013 9:55 am
by philtrate
thebassmasta wrote:I did exactly the same thing dude on the way home from brid, obviously the wind was a major factor, she gave up on me 22 miles from home. I was thinking about a readspeed 6 plate but people are telling me just to put a 5 plate in, Im reading all the posts regarding clutches and still havent made my mind up. CONFUSED DOT COM. It all boils down to budget, others im considering , SSC/Morris 5 plate, around £180 but not seen much info on them, MB 6 plate, looks good but its well over £400, woudnt touch the AF cassette type road version, you need arms like popeye to pull it in, but the race version is supposed to be better, Just need a very good clutch to handle a 24bhp imola
I've got the AF road cassette clutch in my RB it's so light and easy to use and I'm no popeye
Posted: Sun Nov 17, 2013 10:39 am
by lozmondo
AF road clutch in a 30 bhp monza, properly routed nylon lined cable, lovely
Posted: Sun Nov 17, 2013 6:52 pm
by thebassmasta
what oil you using? in your af clutches? i was only going on experiance with my mates jet200, i would like to think that hes routed it badly cos they do look a nice bit of kit and affordable
Posted: Sun Nov 17, 2013 9:23 pm
by roadrunnerian
i have an af road clutch in my ts1 i run with standard gear oil although some people use a lighter oil, my clutch is very light nylon cable and dog leg lever a top clutch m8
Posted: Sat Jan 18, 2014 5:27 pm
by mickdale
andy francis website says af cassette clutch road "new version"
is there a modified/updated/better version to the older ones available?
if so are they more reliable/better?
Posted: Sun Jun 26, 2016 12:20 pm
by Norrie Bodge
Sorry to revive this old thread!! But?
Which clutch is it that one recommends then for higher BHP lambrettas ?
My TS-1 230 with 6plates & atomic deep spider/pressure plate & std crownwheel notched for the 1st cork is slipping bigtime at 50+
Was fine b4 I altered my drive sprocket from 19 to 20 ??
All replies appreciated
Posted: Sun Jun 26, 2016 2:31 pm
by Norrie Bodge
Posted: Sun Jun 26, 2016 6:41 pm
by Lambretta Sash
What do you call high hp?
Af cassette is not my choice, lth is good as is bgm one as I've recently fitted to avanti sprinter .
You can run st 4plate with right springs and prob get 2 years out of it as fond on our Rt @ 27hp motor.
Posted: Sun Jun 26, 2016 7:25 pm
by Norrie Bodge
High HP is IMO TS1 RB20 220 250 etc etc m8
Posted: Sun Jun 26, 2016 7:43 pm
by coaster
Norrie Bodge wrote:...............Was fine b4 I altered my drive sprocket from 19 to 20 ??
Are you sure it isn't the front cush drive slipping? wouldn't be the first time some miss-assembly has caused this.
