Re: H4 headlight conversion
Posted: Sat Nov 09, 2013 12:31 am
I'm just in the process of doing an H4 conversion at the moment which is basically the same as Coaster's, (just a little more radical with the surgery on the old bulb holder
Apart from getting a better light, one of my objectives (I have a SIP speedo, hydraulic brake hose and indicators attached to the headset) was to get a little more room in the headset.
First thing was to check the focal lengths of the old BA20 bulb and the new H4 to ensure a half decent beam pattern with a standard reflector/headlamp glass. This worked out quite well by removing the metal collar from the old bulb holder (a CEV type) and modifying and the H4 bulb like this:
This is how it now looks mounted in the reflector assembly:
I sliced off the back end of the original bulb holder and used JB Weld to glue it to the back of the H4 connector, so I could use the original spring clip fixing:
And this is how it fits:
Fortunately I had a spare broken bulb holder to butcher and play with allowing me to return to standard if this setup causes any problems.
It should be noted that I have dispensed with the useless side/parking light so it might not pass the UK MOT.
I'm hoping that my SIL 12v stator/BGM regulator has enough grunt to power the 55/60w bulb, but at least I have a BGM LED rear light to give it a fighting chance.
Today is final assembly day so I should see if anything shorts/melts/blows up very soon!
