Page 2 of 3
Re: Another Holed imola Piston....AAaargh
Posted: Fri Sep 27, 2013 9:48 pm
by speedy
The confusing bit is that you have two pairs of tights.
Posted: Fri Sep 27, 2013 10:21 pm
by CutdownSpence
No good using holed fish nets tho
Posted: Fri Sep 27, 2013 10:56 pm
by speedy
Just asked the wife and only tights with a comfort gusset and/or reinforced toe will be enough to completely filter your fuel.Hope this helps.
Posted: Sat Sep 28, 2013 9:15 am
by nellyboyo
speedy wrote:The confusing bit is that you have two pairs of tights.
CutdownSpence wrote:No good using holed fish nets tho
You boys are on the wrong forum
Anyway , off down the cave now to drop the engine, take the tank out, replace the carb.......and she thinks I`m going shopping
Posted: Sun Sep 29, 2013 10:23 am
by nellyboyo
While I was stripping the engine down I found the exhaust half full of petrol ??
This has now totally confused me , my fault finding skills are out the window.
The petrol was turned off and there was a puddle under the scoot from the exhaust stub I think .
The scoot is telling me something and I can`t work it out.
Any help appreciated
Posted: Sun Sep 29, 2013 1:40 pm
by rbgaz
exhaust full of petrol , could be broken reed petals
Posted: Sun Sep 29, 2013 1:45 pm
by nellyboyo
Cheers for that , I`ll check
Posted: Mon Sep 30, 2013 8:33 pm
by jonny snatchsniffer
pwk copies are hit and miss too
Posted: Tue Oct 01, 2013 11:15 am
by soosh
jonny snatchsniffer wrote:pwk copies are hit and miss too
Sure,float needle jet needs drilling out,did mine to 3mm.Possible float height adjustment required too.
My motor tried to nip up with this carb,luckily its iron so it did that way before it thought about holing the piston.
Posted: Wed Oct 02, 2013 1:45 pm
by nellyboyo
Its a stage 6 pwk .....a better quality pwk copy
The float height seems fine and I checked the reeds which were fine too. I`ll go in and drill the needle jet out .
Its up and running now and just checked the timing which is 18 deg spot on,
Just waiting for my new tank to arrive.
Still confused by all the petrol in the exhaust though ????? a good half pint sitting in it ???
