Re: RB20 dyno
Posted: Tue May 12, 2009 1:26 pm
shocky wrote:PROB A 3RD GEAR RUNRinB wrote:Not bad out the box
One thing I query is your gear ratio 4.8 yet only get 68Mph @8600
Doesn't calc out ??
Doesn't calc out ??
Jetting tmx35drunkmunkey6969 wrote:What jetting are you running, and what was your Air/Fuel graph like? Did Readspeed discuss lean/rich spots with you or what jetting changes could be made? Top end power after the peak seems a bit rough, any further info?
I think that's why it feels rich at quarter throttle, the slide is possibly too rich.carlos fandango wrote:
slide 4
It still feel rich at quarter throtle.
Bufficus wrote:I think that's why it feels rich at quarter throttle, the slide is possibly too rich.carlos fandango wrote:
slide 4
A number 6 slide is used for most Lambretta applications.
I recently took the dremmel to a number 6 slide and removed more material on my TS1 too make it leaner at 1/4 throttle.
It was already on a 58 needle top clip, but was still too rich.I had nowhere else to go needle wise. I should add it is not a standard barrel.
Don't all two strokes have a flat spot at around 5000rpm?carlos fandango wrote: my main concern after thinking afterwards was the flat spot at 5200 rpm, and what causes it?
