Timing with different casing?
faf
Main scooter: GP 230 Mugello
lambro wrote:
Donnie wrote:
faf wrote:Apologies if this is a stupid question,but how do you set your timing statically,without the engine running and strobing it?
Google :?: :D
http://www.smellofdeath.com/lloydy/elec_ign.htm
Good for starting points, and then check with a light once up and running.
Yep done that! Put my mouth into gear before engaging me brain :oops:
Donnie
LOL
Donnie.
theageofindustry
Main scooter: 74 Vijai Super
My mid-weight flywheel was in the wrong position and I had to slot it all the way off to achieve the proper timing.
tonydevon
Main scooter: '71 GP125
Im fully clockwise and then some to get my 15 degrees, so I reckon your flywheel boss is out, to be tuther direction and still wrong
eadmr04
tonydevon wrote:Im fully clockwise and then some to get my 15 degrees, so I reckon your flywheel boss is out, to be tuther direction and still wrong
Yep your right, should have read in the original post that I've moved the stator nearly fully CLOCKWISE not anti :oops: :oops: :oops:
I take it that this seems quite normal then and possibly some of the markings might be out on the flywheels? Will be strobing once I've got it started but it's always nice to have a rough starting point.
theageofindustry
I seem to remember my strobing revealed the timing mark on the flywheel was also off considerably.
Funny as I did one for a friend and his was spot on.
tonydevon
just make all your own from scratch, thats what I did, the arrow on my flywheel was pissed and well inboard so difficult to judge
I just put it at the current TDC position, chose a place round at about 3 or 4 oclock position, marked it, took flywheel off, dragged a hacksaw blade across a few times to create a small nick, white spray paint, then wiped just leaving the paint in the groove, refit, find TDC with dead stop, then marked off 15,17,19,21 and 24 degrees, did the same trick with hacksaw blade and paint
now its got lovely clean marks, that strobe up a treat, the other marks will help if it has an mtech or similar fitted
eadmr04
Got the engine in today and fired up. Surprisingly the static timing wasn't far out and the lines on the flywheel did line up pretty much with the black box. I've got it strobed at 16 degrees but had to open the slots in the stator as far as they would go, any more and they would have been open ended!
