Page 2 of 2
Re: Early Imola cylinder head.
Posted: Mon Aug 12, 2013 2:51 pm
by jonny snatchsniffer
i use the barrel, that way both the surfaces are the same, the top of the barrel needs to be flat too so why only do the head
Posted: Mon Aug 12, 2013 6:01 pm
by 10 inch Terror
jonny snatchsniffer wrote:i use the barrel, that way both the surfaces are the same, the top of the barrel needs to be flat too so why only do the head
I was going to do the barrel too.I was going to put permanent marker on both mating surfaces and lap them both. The marker should show any high or low spots. How do you use the barrel to do both?
Posted: Mon Aug 12, 2013 8:17 pm
i lap the head on the barrel using some 1500 grit paste
