Re: How hot is too hot?
Posted: Fri Aug 02, 2013 8:56 pm
Thanks GP 240.
It was just top end rebuild with new crank and bearings. Got a 25mm PHBH carb as part of the kit from Gransport and kept the AF clubman exhaust. I did notice a split in carb rubber as I had overtightened the jubilee clips. I replaced the rubber and it still seems to run hot. So having retorqued cylinder head and replaced carb rubber I will try knocking back timing a degree as suggested as the next step.
I suppose what I really want to know is how hot should the engine feel? If its normal for casings and rear hub (have checked and brake not rubbing) to be too hot to touch then I don't need to worry. But like you said I dont want to be holing a piston on my new kit.
