Page 2 of 2
Re: weird strobe reading
Posted: Fri Aug 02, 2013 11:12 pm
by mac
drunkmunkey6969 wrote:When there is a fault on the ignition, the timing marks will strobe OK at low revs, but under load they shoot all over the place.....it can be anything in the electrical equation, but usually a bad stator/flywheel combo not firing properly. Try a different flywheel first, then a different stator.
Just had the same on a mates RB, fitted a new LT coil all fine a 2000 revs get to over about 4.5/5000 revs and it jumps all over the place, I'm blaming the AF lightened flywheel, had the same problems on my own scooter a few years ago, tried 5 different stators, 4 different CDI's, HT leads, plugs, plug caps etc and it would always missfire at higher revs, fitted a SIL flywheel and it was fine.
