Page 2 of 2
Re: Twisted crank?
Posted: Tue Jul 23, 2013 6:58 pm
by Boo
Harry Barlows the man if you need a crank pin welding and re-truing
Re: Twisted crank?
Posted: Tue Jul 23, 2013 9:16 pm
by camel
loctite requires space for it to go....the pins are too tight in the webs to allow any loctite to settle,it will just push the stuff out on assembly
i clamp the webs with slip guages between the space using a g clamp,i guess anything the correct thickness will do but it must be exact or the clamp will pull it out of alignment then weld the pin and allow to cool
the last one i did like this kept in line nicely.
