BGM Stator AF Flywheel
- drunkmunkey6969
- Moderator
- Contact:
I run an AF lightened flywheel (newer version with doweled magnets) with BGM stator, had to remove 2 laminates to prevent fouling, i use the AFR CDI......all revs and goes well, no problems.
I have just the same problem with a new AF flywheel and BGM. Runs fine with my old Indian flywheel.... Tryed to fit a new pick up, but the one I had (org.piaggio) was to big and was't able to fit the flywheel over it, and swop back..
Should come with compete fitting instructions, including details and pictures on different solutions for AF flywheels. If not, contact your dealer or wait a bit while I try to post some instructions to our website.
Any problems are the result of trying to fit something that is made accurately (bgm stators) to something that is often not (flywheels). In my experience I'd say 9 times out of 10 there are no fitment issues. When there are, they are almost always with AF flywheels.
Thanks for all the replies folks ,
Thankfully me old m8 smiffy will keep you up dated on all the technical stuff as its not my speciality but i can fit stators quick
now.
MAB.
MAB.
RinB
- Main scooter: Reflections in Blue
- Contact:
Oh yes m8 nothing like learning new skills.MAB wrote:Thanks for all the replies folks ,
Thankfully me old m8 smiffy will keep you up dated on all the technical stuff as its not my speciality but i can fit stators quicknow.
MAB.
Next test !
Changing stator in the puring rain stuck half way up Staxton hill on your own.
Smiffy whats the next plan of attack Ducati flywheel
RinB
- Contact:
Well putting on my Inspector Smiffy hat on
Ive just had a thought
Apparently the new BGM stators have been modded so that Pickup sits further Back
(Just confirmed this with Phil At MB's)
Now heres the b@stard bit I think
So If you use a New AFR Flywheel which has had the spacer put in to move the Flywheel away off the Pickup
You are going tobe double whamied pick up in - flywheel out therefore the alignment is worst
So whats happening I think is each part's manufacture is trying to fix problems but not talking to one another and now I think may have made it worst
Not going to say this will be problem on all combinations but certainly one to look at.
Smiffy
Smiffy
Angry Bloke
- registered user
- Contact:
I also run an AF lightened fly and after a self destructing stator am about to replace it with a BGM version so i was interested in the this thread.
I checked the position of the pick ups on an AF stator in relation to the inner face of the mag flange and the dims are 28mm and 35mm (which includes the base thickness of 2.5mm)
The BGM has a base thickness of 3mm but this seems to have been allowed for as the pickups measure 28mm and 35mm.
So ,in conclusion, on paper a new BGM stator should fit the latest version of an AF lightened fly with out modification .
But as I am constantly reminded -You don't build it on paper !
Strummer10
- registered user
- Main scooter: Lambretta LI Special 225
- Contact:
Think it’s not even worth bothering with them lightweight flywheels....just a waste of time setting up to run any good.
