Page 2 of 2
Re: PM Tuning Volante antidive disc brake
Posted: Wed Jul 03, 2013 6:09 pm
by frank sanderson
Did you get the fitting instructions with your hub ? we tell everybody to fit at 90 degrees in the instructions . If you fit at any more or less you run the risk of the problem you describe .above 90 it trys to push outward instead of toward the fork leg below 90 it trys to push in all the force is transmitted toward the joint in the linkage not toward the forkleg .
Posted: Wed Jul 03, 2013 7:04 pm
by RICSPEED
MAB wrote:I have just got the Mito twin disc )
very tasty ..
but can you explane .. 90deg in relation to what ..the caliper arm ..links ??
Posted: Wed Jul 03, 2013 9:01 pm
by RICSPEED
Posted: Thu Jul 04, 2013 2:18 am
by Minority
very tasty ..
Think Frank means like this (this is a ScootRS setup, but same principle should apply):
Posted: Thu Jul 04, 2013 1:27 pm
by Danger
The bracket on the fork leg That the anti dive is bolted too can that be bought separately , and would it work with the pm tunning setup and if it can be bought separately where from cheers danger
Posted: Thu Jul 04, 2013 5:59 pm
by RICSPEED
scroll up I posted a link
Posted: Sat Jul 06, 2013 12:38 am
by corrado
Posted: Sat Jul 06, 2013 1:48 pm
by Danger
Cheers ric
Posted: Sat Jul 06, 2013 1:52 pm
by Danger
I bought a pm tuning anti dive disc brake from tr speed shop but I didn't get any instructions with it would any body have any pics or info on how the hub should be fitted plus it say in the add when I bought it that it was for tubeless rims but the studs in mine are about an inch long at most so there's no way my rim will fit can the studs be replaced an if so were from thanks a really pissed off me ,
