Page 2 of 2
Re: vespa flywheel
Posted: Wed Jun 26, 2013 10:37 pm
by gaz_powell
Well I've learnt something new today !
Re: vespa flywheel
Posted: Wed Jun 26, 2013 11:45 pm
by john
Thanks guys for the replys , I will have a look at the weekend for the overlapping magnets.. As per Beedspeeds link.
Re: vespa flywheel
Posted: Thu Jun 27, 2013 7:33 am
by Adam_Winstone
That's cool if there are flywheels about that will do both. There certainly isn't any reason why you could run a flywheel that has both the cam centre and the electronic trigger on the magnets, just make sure that you have one of these double function flywheels, otherwise you'll have to stick like for like.
Re: vespa flywheel
Posted: Thu Jun 27, 2013 8:08 am
by tha83
Yes you can use it. I have a px 125. The 125 came with points. I put in an electronic stator and I can't remember if I had to slot it to change the firing position. First I rewired the points stator with a bgm trigger. I remember slotting that one. I wish I could remember how many degrees. Someone knows this trick. Someone with a brain.
