Page 2 of 2
Re: dellorto fuel pump
Posted: Thu Feb 03, 2011 9:03 pm
by gimp1971
Diablo did mine on my T5 if you want will take a couple of pics of it and mail them to you
Posted: Sat Feb 05, 2011 3:34 pm
by barneypeter
gimp that would be great this is a diablo built engine ,is vacume on casing or carb,and is there any restrictors in fuel line many thanks,and thanks for all other replies pics very helpfull
Posted: Mon Feb 07, 2011 8:09 pm
by gimp1971
will sort some out for you tomorrow if you want to pm me your email
Posted: Thu Jul 28, 2011 7:33 am
by dopeshots
Why does the vac fuel pump get used and not an electric one?
Russ :fb:
Posted: Thu Jul 28, 2011 2:15 pm
by gaz_powell
vacuum pump is a simple "mechanical" answer it works with the suction of the rotating crank - so as long as the crank is turning the pump is working - you cant get caught out if you have some sort of electrical failure leaving you short of fuel.
Posted: Thu Jul 28, 2011 4:48 pm
by dopeshots
so its nothing to do with fuel pressure or any thing like that then. Ok brilliant I'll look into getting one fitted to mine.
Russ ;o)
