Page 2 of 3
Re: Custom Painting S2 Fibreglass Panels...
Posted: Thu May 05, 2016 3:32 pm
by Rob Brown
I've got some very special painted fibreglass panels with high-line cracks that I'd like to try to repair (without repainting). Has anybody had any luck repairing such cracks?
Thanks for the help
Posted: Thu May 05, 2016 10:28 pm
by coaster
Have you got any photos of the damage? I doubt though that ant repair will be possible without causing more damage. The correct way to deal with cracks is the add a layer or 2 of matting to the rear of the panel and then to grind away the damaged gel coat and grp layer for an inch or so either side of the crack and then lay a layer of fiber glass tissue cut to match the ground out area. a skim of filler is then applied and the repair sanded flat.
That method will garuntee that the cracks don't reappear later.
Posted: Thu May 05, 2016 11:18 pm
by Doom Patrol
The fibreglass panels do look good. But metal is so much easier.
Posted: Fri May 06, 2016 5:43 am
by DigDug
Doom Patrol wrote:The fibreglass panels do look good. But metal is so much easier.
Easier to what Neville Rust?
Posted: Fri May 06, 2016 10:50 am
by Rob Brown
Here are the hair-line cracks I'd like to improve. Repainting is not an option, so if I can't do anything about the cracks I'll live with them; I'd appreciate anybody's thoughts:
IMG_1427 by
Robin Brown, on Flickr
IMG_1428 by
Posted: Fri May 06, 2016 2:12 pm
by matthew
Are they Jem's old race bike panels? Personally I'd clean them up and clear coat them and accept that they've got some history.
Posted: Fri May 06, 2016 2:27 pm
by Rob Brown
Yes they are (well spotted!). I'm with you 100% I like them showing their history, and will leave the cracks unless there is a good way to stabilise them.
Posted: Fri May 06, 2016 3:51 pm
by EddieStone
You can probably make those cracks a lot less visible by cleaning the panels with oxalic acid, then possibly a clear lacquer.
Posted: Sat May 07, 2016 7:35 pm
by Doom Patrol
DigDug wrote:Doom Patrol wrote:The fibreglass panels do look good. But metal is so much easier.
Well, there is that. Swings and roundabouts I suppose. But generally speaking a metal panel shouldn't craze like that.
Posted: Sun May 08, 2016 6:06 pm
by coaster
Looking at the cracking I would hazard a guess that the dam
age has possibly been caused by banging on the panel to get it to 'snug' home. It's in a similar position the where I thump my steel panels. The damage to the main part of the panel is down it flexing due to there not being enough laminations. Ideally you need to reinforce the rear of the panel but I can see that might make the panel difficult to fit but definitely worth looking into even if its just a layer or 2 of tissue near the lip rather than mat.
2k lacquer is quite flexible so as has been said already, a couple of good coats should seal the damage. Good luck
