mostly nonesense: stainless steel stuff
Soulpunk
Hot-dip galvanized steel is well suited for use in a variety of environments and fabrications, and sometimes is placed in contact with different metals including, among others, stainless steel, aluminum, copper and weathering steel.
When two different metals are in contact in a corrosive environment, one of the metals experiences accelerated galvanic corrosion while the other metal remains galvanically protected.
Metals near each other in the galvanic series have little effect on each other. Generally, as the separation between metals in the series increases, the corroding effect on the metal higher in the series increases as well.
Relative surface areas of contacting dissimilar metals is also relevant in determining which metal exhibits accelerated corrosion. It is undesirable to have a large cathode surface in contact with a relatively small anode surface.
Galvanic corrosion occurs when two different metals are in contact in a corrosive environment: one of the metals experiences an accelerated corrosion rate. The contacting metals form a bimetallic couple because of their different affinities (or attraction) for electrons. These different affinities create an electrical potential between the two metals, allowing current to flow.
The metal higher in the galvanic series of metals, the “anode,” provides protection for the metal lower in the series, the “cathode.
