Page 2 of 2
Re: Cyclone box with drops.
Posted: Sat May 11, 2013 12:34 am
by RICSPEED
as was mentioned the 1- 4 and 1 - 5 lever possition is the same .. the problem is that drop bars are more suited to the profile of gp leggies than the sx type
Posted: Sat May 11, 2013 12:44 am
by Muttley McLadd
It's a 30 second fix.
Tin snips. Legshields.. go..
Posted: Sat May 11, 2013 6:41 am
by doggbhoy
i fitted drops to a spaniard and the gear change housing and the hydraulic yam brake lever bolt were both fouling.....if you have the longer italian forks and already have been using the yamaha type master cylinder... you should be ok , you will find out soon enough
let us know how it goes and good luck
Posted: Sat May 11, 2013 7:29 am
by 10 inch Terror
Muttley McLadd wrote:It's a 30 second fix.
Why didn't I think of that?
Posted: Sat May 11, 2013 8:34 am
by warts
Full lock? Top gear? Bugger!
Posted: Sat May 11, 2013 5:16 pm
by Timbo
Timbo wrote:Not sure this is true, best to check with Riminni or someone that's got drops. My cyclone in 5th appears to be further down.
4th and 5th are in the same place as previously stated...
Posted: Sun May 12, 2013 12:12 pm
by Muppet
Y got no more room in the gear box for y five speed as was for y four speed; so selector slides same same same; cables pull an push y selector tie rod same same so y still got same same for sure if y ain't mucked up your cables or y got slack in y headset or linkage,
