Page 2 of 2
Re: 26mm PHBH on 200/225 stage 4?
Posted: Fri May 10, 2013 8:11 pm
by Timbo
Good point Martin, thanks.
Posted: Fri May 10, 2013 9:10 pm
by corrado
I put some masking tape around the throttle where it butts up against the light switch housing then put a piece on the switch housing too. Put corresponding marks at zero throttle, then twist throttle to full open and mark that position on the throttle, then divide into 8 segments from zero to WOT [wide open throttle], then you can do your plug checks at set throttle positions. Plug chops best done on a decent road with frequent laybyes to use. Hold throttle at set point, switch off ignition, immediately pull in clutch and coast to a halt, preferably in the laybye where it should be safer to remove the spark plug, that gives a snapshot of the plug at the time of switching off the ignition. Ideally you'll have held it at the same throttle position for at least a couple of minutes.
Posted: Sat May 11, 2013 8:15 am
by Timbo
Thanks Martin........what you up to today........
Posted: Sun May 12, 2013 1:01 am
by corrado
Doing plug chops would have been a better day than digging out a tree stump.
Posted: Sun May 12, 2013 8:39 am
by Timbo
corrado wrote:Doing plug chops would have been a better day than watching the Cup Final
Fair point.....
Posted: Sun May 12, 2013 11:27 am
by storkfoot
corrado wrote:Doing plug chops would have been a better day than digging out a tree stump.
Thought you'd be watching the cup final, mate? Oh, sorry, don't suppose you wanted to be reminded of that
Posted: Sun May 12, 2013 2:10 pm
by corrado
Even digging out a tree stump was preferable to watching that FA Cup performance.
