Page 2 of 2
Re: PWK Filter elbow/hose
Posted: Mon May 06, 2013 9:09 am
by thebassmasta
i just dip the end of the rubber in boiling water, softens the rubber once shes on she will be ok
Posted: Mon May 06, 2013 1:18 pm
by Minority
Thanks for all the replies, sounds like the Evergreen/Camlam 55mm might be what I'm looking for.
BTW, early days but impressed with the PWK so far!
Posted: Mon May 06, 2013 2:59 pm
by dapper
I would also suggest you replace that fuel tap with a fast flow rear exit and a shorter length of fuel pipe, as that's a large air bubble in the fuel line. Have you done the mods to the PWK as they have had issues with fuel starvation, hence my advice?
Posted: Mon May 06, 2013 3:43 pm
by Minority
dapper wrote:I would also suggest you replace that fuel tap with a fast flow rear exit and a shorter length of fuel pipe, as that's a large air bubble in the fuel line. Have you done the mods to the PWK as they have had issues with fuel starvation, hence my advice?
The air bubble was just when I was messing about and I'm still finalizing various installation niceties like fuel hose routing.
The fuel tap is a Camlam fast flow (would prefer a rear exit, but this one was on the scoot when I got it) and I've done all the mods that I can find on the forums (all advice welcome BTW).
