Page 2 of 2
Re: Blown exhaust gasket
Posted: Sat May 04, 2013 12:24 pm
by DaveTomo
I'd also consider using something like this
http://www.ebay.co.uk/itm/V-Tech-Vital- ... 27cf86fc5b it'll spice up your sandwich.Use it on mine on the slip joint and the on both sides of the copper gasket on the manifold,been bob on no leaks or blowing
Posted: Sat May 04, 2013 1:37 pm
by dapper
I seem to remember that the solid copper gaskets should be heated until cherry red and then allowed to cool to anneal them. Then linish both faces of the gasket on some wet 'n dry fixed to a piece of glass. Also linish the gasket face of the U bend so that all surfaces are completely flat. A smear of HT silicone gasket sealer and wire locking exhaust nuts, and Bob's ye uncle.
Posted: Sat May 04, 2013 2:17 pm
by OAP
maybe a stupid question but why did you not use the one I supplied with the kit?
Posted: Sat May 04, 2013 3:11 pm
by sideout
OAP wrote:maybe a stupid question but why did you not use the one I supplied with the kit?
Not a stupid question Ron, that's a GOOD question!
Shame I haven't got a good answer......
Posted: Sat May 04, 2013 4:36 pm
by Adam_Winstone
^... lol!
Posted: Sat May 04, 2013 6:28 pm
by Timbo
Posted: Sat May 04, 2013 8:53 pm
by Grumpy225
dapper wrote:I seem to remember that the solid copper gaskets should be heated until cherry red and then allowed to cool to anneal them. Then linish both faces of the gasket on some wet 'n dry fixed to a piece of glass. Also linish the gasket face of the U bend so that all surfaces are completely flat. A smear of HT silicone gasket sealer and wire locking exhaust nuts, and Bob's ye uncle.
To correctly anneal copper you need to heat it up bright red and then quench it in cold water. This is opposite of steel working where quenching hot steel makes it harder, copper gets softer. I have to anneal the copper soft jaws on my vice about once a year or so, so they stay soft. Theres some elemental physics involved as to the why and how but that's boring stuff.
Posted: Sat May 04, 2013 10:22 pm
by Toddy
sideout wrote:OAP wrote:maybe a stupid question but why did you not use the one I supplied with the kit?
Posted: Sat May 04, 2013 10:33 pm
by Muppet
you muppet
Posted: Sat May 04, 2013 11:27 pm
by sideout
Muppet wrote:sideout wrote:OAP wrote:maybe a stupid question but why did you not use the one I supplied with the kit?
you muppet
said another muppet,,,,
