Page 2 of 2
Re: water cooling a standard head.
Posted: Wed May 01, 2013 6:09 pm
by billet-jimmy
that other drawing was just a play around, nothing was exact to size or shape, but these drawings are the exact dimensions and design. just need to put the stud holes in and the wholes and spigots for the lid, which ill draw up this week or next week sometime, any ideas on the water flow are welcome, at the minute there is a partition wall to help the water flow round.
Posted: Fri Jun 28, 2013 9:46 pm
by billet-jimmy
Posted: Sat Jun 29, 2013 8:33 am
by Spanish Fly
B-J
Watching with interest. Nice bit of machining.
The cylinder head bolt holes appear to break out into the water chamber which will create a leak path. What is your plan to overcome that?
SF
Posted: Sat Jun 29, 2013 11:06 pm
by billet-jimmy
titanium cylinder studs so it doesnt rust and its going to be quite a tight fit in the holes plus im going to spot face it and fit a rubber washer which should hopefully stop it from leaking. the lid for the top will also be sealed with two o-rings, outer diameter and the inner diameter where the spark plug will sit.
Posted: Sat Jun 29, 2013 11:20 pm
by RICSPEED
a lot of the newer lc topends have a separate head and skull cap anyway so if they don't leak this shouldn't do .. most ive seen for lammyies use copper washers same as break lines
Posted: Wed Nov 06, 2013 2:20 am
by Terrible Taff
Have a look at Duncan Cully's Vespa PX220-LC (221cc) Revamp 2013 in my photo albums - Ian Frankland on Facebook or give me a call if you need info also we do cast LC head blanks for machining if you need them?
