who would build the following t5/ts1 conversion
C*NTSPEED
OzOAP wrote:I built it in 2005 but I would listen to the experts Ducksta.
and everytime I hear it and see it I get a twinge in mi undercrackers...awesome scooteh
GEMINI S.C.
BLACK WIDDA'S S.C.
readspeed will do it they have DONE a 230cc lambretta LN ONE OF THOSE NEW AUTO ONES think the motor cost 3k
OzOAP
Main scooter: Vespa PTS1E
:D :D :D
So do I mate. Had all the fuckwit comments over the years...
"waste of a TS barrel"
"more power sticking with a T5"
"would be better fitting a bike cylinder"...blah, blah
Pleased its still getting discussed 8 years on.
ducksta
how much for the cases gin23
tony172
Main scooter: vespa t5
oz your pts1e is my all time favorite scooter bar none.
f@@king brilliant idea- and f@@king brilliant bike
ducksta
cheers guys i would rather listen a bit more to the builder of the engine, so oz whats the fuel consumption like, maintainance, and ridability of the scoot.
C*NTSPEED
SCOOT GOES LIKE f@@k
IT SOUNDS THE NUTS
ITS HEAVY ON BOTH OIL A JUICE
AND OZ IS A c**t FOR DOING SUCH THINGS VWITH AN INFERIOR LAMBRETTA BARREL
:D :D :D :D :D :D
GEMINI S.C.
BLACK WIDDA'S S.C.
OzOAP
Had one piston in it. Covered bout 12000mls now. Not a lot over the years but I use a few other bikes as well.
It'll do about 80 miles on a 12lt tank, give or take a few either way. It drinks fuel at either 50mph or 80mph, in between it's not to bad. I run it on 3% Castrol TTS (or whatever it's called nowdays).
Last dyno run at Diablos, (highly recommended), to set up powerjet was 27hp/20lb. Not ground breaking TS figures by any means, its a 220cc with a few tweeks.
Used it on two rallys last year, Darkside and Salford Knights 30 Anniversary. Got trophy at each. Nice considering its been around a while.
Have trawled the internet for info on long stroke T5s that the 'expert' was bigging up, cant find anything apart from off-set pins and a crank for £425. No builds/dyno sheets.
Reason for building it? I was once told that whatever I do to a P Range, I'll never beat a TS1...
If you can't beat em, join em!
ducksta
cheers oz ime just looking to do something slightly differant to my next engine so am catching up on what has been done before then decide what suits my budget and style of scootering.
OzOAP wrote: Reason for building it? I was once told that whatever I do to a P Range, I'll never beat a TS1...
You were told wrong: http://scooterotica.org/forum/viewtopic ... 46&t=25449 :shock:
That's a 30bhp 210, and the 210 transfers are shite compared to a T5......so don't write off Vespa cylinders just yet! ;)
Personally I think the port/time area and entry angles of a 172 cylinder is far superior to a TS1, but the obvious lack of CC hides this fact. So the extra 50cc the TS1 puts out goes a long way to redressing that balance. But I also think the largest amount of production 'off the shelf pipes' for Vespas are shite too, which has a massive effect on power. Unlike the TS1 which has quite a few 'off the shelf' options which can produce very good power.....so its easy to be misled on this subject.
I'd have to believe that if the T5-172 kit was ported a little, stroked a lot (with correct packers/port time area/duration set up) and matched with a Vespa equivalent of a Franspeed Race or a PM Fat Mamba, then you'd have a better balanced and more powerful motor than by strapping a TS1 cylinder to a Vespa. In fact i'm certain that if a 225 TS1 had the same port time area equivalent which the T5-172 kit has then it'd be a powerhouse 'off the shelf'!! Still........neither option is going to stop the P-range casings (made of cheese) cracking everywhere though, and that's the main problem.
That aside, the Vespa/TS1 conversion in my eyes is one of those wonderful feats of engineering, which is quite esoteric and interesting, and one that is done to........well, see what can be done! For the enjoyment factor, and flying in the face of tradition etc. Pretty much the same reason we all fettle ANY scooter and try to get 40+bhp out of shopping trollies etc. But I wouldn't see overall balance and power as the main reason for this conversion. :geek:
    Users browsing this forum: Google [Bot] and 33 guests
