Page 2 of 6
Re: RAPIDO 42 BHP to start with.
Posted: Tue Apr 16, 2013 10:40 pm
by Ken Tucky
Looking good Shaun.
You might need a chest pad on the headset with that power!
Mr Tucky
Posted: Tue Apr 16, 2013 11:17 pm
by willwander
Awesome power and lovely looking graph.
Already fastest man at over a 100mph on a Vespa PX and now hopefully on a Lambetta.
Lumpy Custard strikes again.
Posted: Wed Apr 17, 2013 12:07 pm
by Dryballs
Muttley McLadd wrote:That's a lovely colour. Is it green or yellow in daylight?
It's the same colour as your lacquered snail isn't it?
Posted: Wed Apr 17, 2013 12:29 pm
by drunkmunkey6969
Excellent result. When are you posting the port timings and port map? Lol ;0)
Posted: Wed Apr 17, 2013 2:28 pm
by Muppet
Mahoosively great muchness on yer power graphs
y must be runin a wide exorst port? tis bridged? a steel linered pot with a Floating bridge?
Posted: Wed Apr 17, 2013 7:40 pm
by fairspares
Been to the dyno again this afternoon and the franspeed will not let this setup rev much over 9k , we tried a race pipe but that just wouldnt let the engine rev so now need to look at getting one made to suit. sorry i cant give away the port timings etc but i can say its nothing ott, no bridging of the exhaust port but yes wide,ish. Transferes are standard and only cleaned up then matched to casings, i have gone for a slightly different approached in the way the inlet flows into the transferes around the casings that combined with all the other work seems to be working so far.
Posted: Wed Apr 17, 2013 10:22 pm
by Darrell Taylor
how did u get on today Shaun , did it make the 45 ?
Posted: Wed Apr 17, 2013 10:37 pm
by fairspares
No Darrell just tipped over 42 then dropped at 9000 , im over the moon with whats its got now but would have liked it a little higher up the rev range, im not sure how much the clutch and gearbox will take as it is, so i think its best to just do a few meetings and test it out first. its ok having loads of power but if i cant launch it from the line under control it aint going to be quick.
By the way Darrell have you done any testing with and without the reed stuffer in the v force reed block?
Posted: Wed Apr 17, 2013 11:15 pm
by Darrell Taylor
im over the moon for you too great result by all concerned,hope the weather and wind is with u at the weekend and u should see some great times and speeds,whats it tip the scales at now?i guess 80kg
interesting stats from last shootout
lightweight gp 4 with 30bhp lightweight but std aero package
your superlight sprinter with was it 24bhp very lightweight improved aero package
erics rb250 42 bhp 125kg very heavy std aero package
all made similar times/speeds at the shootout so the gp 4 weight drop was worth around 12bhp
and the extra weight drop and improved aero was worth near 18 bhp
so really keen to see what yours will do in the light chassis,improved aero set up
should have been there too but at mallory this weekend ,think i might make the next date without it clashing,im building a sprint light li125 too that should be done mid season
the vforce likes a matching carb size approx 35mm so on your 39 may like a bigger stuffer opening not tried back to back ,but seen improvements from stuffing reeds so think will be a loss removing it alltogether
Posted: Thu Apr 18, 2013 11:26 am
by fairspares
Your right it weighs around 82 kgs , its been going through my mind to put it in the lightweight frame for this coming sunday , especially as the rear panel/footboard legs which is where i put my feet have already started to crack on both sides and need welding. will do some testing next week without reed stuffer, as its only thrashed through the 4 gears and kepted in high revs wondered what difference this would make? look forward to seeing your comp sprinter out with the sorts of power that is being produced at the moment will some of the long standing sprint records be beat? be nice to join the 12 sec club.
Ryan Saxelby......12.70.......Elvington 2002?
Keith Terry........12.70....... 104mph Sculthorpe.
Stuart Owen.......12.71 ?
James Campen ... 12.72 ....@ 99.6 mph ... scooter shootout Elvington 15th sept 2012.
Darren Scott.... ..12.74.......Melbourne 12th May 2002.
Darren Hawkins...12.81.......100.68 mph Santa Pod 1999.
Trev Harrison.....12.82.......104mph Santa Pod.
