Page 2 of 3
Re: What's going on?
Posted: Sat Apr 13, 2013 3:13 pm
by ducksta
no i never :cry:
Posted: Sat Apr 13, 2013 3:22 pm
by mick1
Oh yes you did :oops: ....... :lol:
Posted: Sat Apr 13, 2013 7:39 pm
by djh66
Diving into the clutch now! Will report back
Posted: Sat Apr 13, 2013 8:41 pm
by djh66
After taking the clutch cover off, I noticed that the clutch arm is very stiff, after freeing it up slightly, should the spring be returning it? cause mine doesn't, this I think is the problem!
I'm assuming here, that the clutch arm can come out of the cover, but how? :?
Posted: Sat Apr 13, 2013 8:51 pm
by Shaunbond
Spring should return the arm. Unclip the spring (whatch your fingers) and the arm will pull out, keep an eye on the small lever which pushes on the brass plunger or you may lose it. Give everything a good clean grease and reassemble.
Posted: Sat Apr 13, 2013 10:38 pm
by djh66
Well.........I eventually got the clutch arm out of the clutch cover, and found one of the two o'ring's had split and chewed up, causing the arm to be very stiff, hence not returning when the clutch was pulled in. Cleaned, found new o'ring, greased and re assembled. Now all seems ok, but will test tomorrow. Cheers for everyone's advice.
Posted: Sun Apr 14, 2013 11:34 am
by GLscoot
Did you check the brass plunger had not mushroomed and the pressure plate was ok. If the pressure plate on the clutch is very smooth and you can feel a groove on the plate, you will need to replace both plunger and pressure plate. You can test this by depressing the kickstart, if there's no resistance, you will need to replace these parts.
Posted: Sun Apr 14, 2013 1:41 pm
by djh66
Road tested today, now all ok :)
Posted: Mon Apr 15, 2013 10:23 pm
by ducksta
quote mick 1 (One of the lads who posts on here dropped the woodruf into the gearbox......careful on that one as well.)
it was never found not even when it had a full strip so innocent till proved i would say :D
Posted: Fri May 09, 2014 3:37 pm
by markauk
Ive just dropped the brass plunger, it must have gone into the engine, any ideas or is it time to split the cases??
and yes I felt like a total idiot when it happened ;(
