What's going on?
ducksta
no i never :cry:
mick1
Main scooter: Li Avanti 225
Oh yes you did :oops: ....... :lol:
djh66
Main scooter: 150 special
Diving into the clutch now! Will report back
Bring Me Sunshine COYH
djh66
After taking the clutch cover off, I noticed that the clutch arm is very stiff, after freeing it up slightly, should the spring be returning it? cause mine doesn't, this I think is the problem!
I'm assuming here, that the clutch arm can come out of the cover, but how? :?
Shaunbond
Spring should return the arm. Unclip the spring (whatch your fingers) and the arm will pull out, keep an eye on the small lever which pushes on the brass plunger or you may lose it. Give everything a good clean grease and reassemble.
Serial scooter rider...
VMSC Committed to Scootering for 25 years
djh66
Well.........I eventually got the clutch arm out of the clutch cover, and found one of the two o'ring's had split and chewed up, causing the arm to be very stiff, hence not returning when the clutch was pulled in. Cleaned, found new o'ring, greased and re assembled. Now all seems ok, but will test tomorrow. Cheers for everyone's advice.
GLscoot
Main scooter: Vespa GS150
Did you check the brass plunger had not mushroomed and the pressure plate was ok. If the pressure plate on the clutch is very smooth and you can feel a groove on the plate, you will need to replace both plunger and pressure plate. You can test this by depressing the kickstart, if there's no resistance, you will need to replace these parts.
djh66
Road tested today, now all ok :)
ducksta
quote mick 1 (One of the lads who posts on here dropped the woodruf into the gearbox......careful on that one as well.)
it was never found not even when it had a full strip so innocent till proved i would say :D
markauk
Ive just dropped the brass plunger, it must have gone into the engine, any ideas or is it time to split the cases??
and yes I felt like a total idiot when it happened ;(
    Users browsing this forum: No registered users and 60 guests
