Re: Castrol A747 Oil
Posted: Tue Apr 09, 2013 8:43 pm
this is info ive found for another caster based oil
I will be doing the same myself, apparently rock oil do one aswell , as do morris and silkolene
WARNING!!!!!!!! This a not a synthetic oil and will NOT mix with any other oils! If changing over from any synthetic oil, then the following must be adhered to: drain all existing fuel from tank, pour a tiny amount of pure petrol into the tank and run for a very short amount of time-eg ,1-2 minutes on TICKOVER, only to clear out the fuel lines, carb, and whatever remnants of 2 stroke oil are left in the engine, then stop the engine, re-fuel with the correct amount of Castor 927 and petrol, and remember to mix thoroughly as Castor based oils tend to be thicker than other 2-Stroke oils. Shake the container or scooter vigorously!
Recommended for all tuned Lambrettas, Alloy and Cast Iron tuned Lambrettas, high revving Lambrettas, etc etc, not really designed for standard engines.
