grips
bristolmod
ArmandTanzarian wrote:Put the grips in boiling water for a while and then squirt hairspray into them. The heat makes them stretchy enough to go all the way to the headset and the hairspray drys and keeps them in place.
This works very well as you can normally take up any "shortfall" by pulling the hot water soaked grip right to the end- the hairspray then acts like glue and keeps it in place. You can also use the same technique for stretching those oh-so-short condoms on as well :D
Chris
Scootering since 1968.
