Page 2 of 6
Re: 12volt DC Mod charger
Posted: Sat Mar 30, 2013 8:14 am
by paul lester
that thing looks cheaper can we make our own anyone know how to wire it
Posted: Sat Mar 30, 2013 2:44 pm
by firekdp
Should be able to build one much cheaper, a bridge rec (about £2) to first rectify the AC. Just Google the 7812 for smoothing cap values.
It may even be worth looking at 7805 regs to feed out straight to a usb connector.
Posted: Sat Mar 30, 2013 3:24 pm
by mick1
Is there a potential problem in that at low revs it won't be generating 12v. A gps for instances, takes a bit of time to find and connect to the satellites, so at low revs it would switch off then re-start when it reaches 12v ....then switch off again at low revs.
I buggered my samsung galaxy using a gps app' on the Li and that was through a battery....some electrical appliances are a bit sensitive so be careful !!
Posted: Mon Apr 01, 2013 12:01 am
by sideout
firekdp wrote:Should be able to build one much cheaper, a bridge rec (about £2) to first rectify the AC. Just Google the 7812 for smoothing cap values.
Couldn't post a circuit diagram could you mate? It would be really interesting! You made it sound so simple ;)
Posted: Mon Apr 01, 2013 9:39 am
by Knygall
See these at Scarbro' this weekend... I'd priced new new stator, cdi and reg for dc conversion... Think this is worth a try first at that price.... If it does as it says.. Charges phone/ runs satnav.. I'll be happy!!...
Posted: Mon Apr 01, 2013 9:56 am
by rbgaz
y not just use the bgm one straight swap for u org one , only bout 20 pounds
Posted: Mon Apr 01, 2013 10:08 am
by Knygall
I'd priced up all the bgm parts.. Running Af's electic kit at min... Got price for bgm cdi , £20+ , but was under impression I'd need. Battery too???.....
Posted: Mon Apr 01, 2013 10:10 am
by rbgaz
no u can use the bgm without a battery it should hav enough power to run a phone,sat nav
Posted: Mon Apr 01, 2013 10:13 am
by rbgaz
Posted: Mon Apr 01, 2013 10:14 am
by Knygall
I didn't know that!.. Cheers for the info..
