Page 2 of 2
Re: NEW carb on muggello 186
Posted: Fri Mar 15, 2013 10:35 pm
by sideout
thebassmasta wrote:sideout wrote:Not in your list, but a Mikuni TM24 through the airbox with a clubman is sweet; alternatively is great fun with a Ram Air and JL3 both on Mugello 186s.
who sells TM24s? and would also need cable choke. do you have any idea on the jetting running a ram air and jl3 pipe?
Justlambretta.com is your friend
Corrado on here is a jolly nice chap who may be glad to help (if he's finished building his GP)
The TM24 jetting I use on a Ram Air and JL3 is:
main: 180
needle: 5N14, clip 1
pilot: 15
gearing: standard GP200 (1:5.22 final drive)
I know you'll know this already, but in case someone else reads this: Which ever carb you choose, start rich and check your plug often.
Posted: Sat Mar 16, 2013 11:44 pm
by bing crosby
Supereibar wrote:Doing a Muggy for a client, is anyone running a 25PHBL? I want to run it through the airbox...
i have the 25phbl with a clubman and ditched the airbox as it was strangling the muggello kit,what a difference.
Posted: Sun Mar 17, 2013 12:24 am
by Jxmiddle
Bing, are you running any kind of filter on that 25? I've a muggy 225 running with a 25 thru the air box and it goes well but I feel its a bit held back.
Posted: Mon Mar 18, 2013 12:46 pm
by Donnie
I know of one muggy locally with a lad running a 25phbl, what a palava through the airbox.
Basically, yes he has it through the airbox but made a "filter" out of some 3mm mesh in the shape of the old airfilter, so not really a filter at all frankly, but because it looks like a standard set up hes happy.
Oh, and hes running a 48mm Clubman too and it does go very well.
