Page 2 of 2
Re: Piston advice Plus
Posted: Fri Mar 15, 2013 3:27 pm
by dapper
Yes, I'd followed that thread Paul NI, but wondered whether the distance around the cylinder that the inlet port swept may be a guide as to whether the cylinder is Stage 4, or the distance from the top of the cylinder to the tope of the inlet/exhaust etc, would give a guide as to whether the cylinder had been tuned from standard. As I was given the top end and I don't have another to compare it to of known tune, I'm sitting here shrugging my shoulders.
Posted: Fri Mar 15, 2013 4:14 pm
by sean brady scooters
That cylinder looks pretty std to me. The top of the barrel to top of the ex/port on a typical stage 4 would be 34mm to 36mm
Posted: Fri Mar 15, 2013 4:43 pm
by Train Driver
Posted: Fri Mar 15, 2013 5:05 pm
by dapper
Thanks Sean. Have measured and actual dimensions are
Top of cylinder to top of exhaust = 40.5mm
Top of cylinder to top of inlet =75mm
Top of cylinder to top of transfers = 47.5mm
Does that give any clues?
Posted: Fri Mar 15, 2013 5:07 pm
by dapper
Posted: Fri Mar 15, 2013 5:29 pm
as far as the inlet port and timing,you would measure from top of barrell to the BOTTOM of inlet port ,
again yours looks std,
inlet ports on stage 4,s are usually lowered to increase the duration but dont forget that cutting some off the piston skirt also does that.
Posted: Fri Mar 15, 2013 5:54 pm
actually Dan and I were just thinking the other day about starting another section on the forum .."port maps" if anyone would be interested.
Posted: Fri Mar 15, 2013 10:28 pm
by corrado
I could do with one of Southampton, always get lost looking for the ferry.
Boom, boom.
Posted: Fri Mar 15, 2013 10:32 pm
