Page 2 of 2
Re: Fitting A 12 Litre Tank
Posted: Tue Mar 05, 2013 12:10 am
by Jazzy
Doom Patrol wrote:Just a thought. Why don't you buy a couple of these and make your own? Should be doable for someone with a bit of welding skill.
http://www.scooterrestorations.com/lamb ... k-kit-sil/
Someone at last years euro (dont think it was andy Francis) was selling tanks with the two halfs welded to gether the wrong way round, so you couldnt fill it up after it was fitted. :lol:
Posted: Tue Mar 05, 2013 1:38 am
by sideout
soulsurfer wrote:....Has anyone else had this problem?
yep, crap aren't they Mike?
I just tilted it to get the best clearance I could, but it doesn't sit right.
This was the "13 litre" tank with the double cut out which turned out to be 11 litres, if you remember? ;)
ebay eh?! pah.... :)
I was tempted to grind the flange back and re-weld it, but I wanted to get Avanti run in.
Try tightening the tool box nuts as much as you can, this will help a bit.
cheers,
Nigel
Posted: Tue Mar 05, 2013 11:24 am
by PRE0ATS
soulsurfer wrote:Has anyone else had this problem?
Yep, got a stainless one from resurrection scooters a while back - came to dry build and could not get the toolbox and the tank in at the same time even without any rubbers! :(
Posted: Tue Mar 05, 2013 11:33 am
by corrado
The tanks are perfect, it's those crappy toolboxes that you insist on keeping. :mrgreen:
Solution, remove toolbox and fit legshield toolbox, then tank fits and plenty of space for your Breath Sweet filter too. :bouncyeng:
Posted: Tue Mar 05, 2013 11:35 am
by corrado
I'll let you have 2 Indian toolboxes for that price if you want to cut ''n'' shut your own.
